Old 12-04-2012, 09:37 PM   #3
MN 986
MN 986's Avatar
Have you considered the AOS? I had the same codes recently and similar idle bouncing, and while I did not necessarily hear chirping, I have read that a failing AOS can make some odd noises. Mine actually made a light hissing sound when the car was warmed up. Check it by trying to remove the oil filler cap while idling. Difficult to impossible to remove indicates a failing AOS. I was amazed at the difference with the new AOS,,, the cap comes right off. I think my AOS was failing for a long time, but it started to smoke upon starting regularly about the time the idle bounce started. It all was resolved with the new AOS.
Good luck.
MN 986 is offline   Reply With Quote
