So now that I found that I have the DME wire colour codes I started looking at the DME functions more closely. Has anyone considered using the 'knocking yes/no' wire on pin 67 to wire up a knock indicator? Or am I misinterpreting what this is for? Sounds like a simple bulb to this would give you a warning.
There also a pin for oil temperature. Dose the non-S '99 986 have a oil temp sensor or is this what it would connect to if I had one? If its just the dial Im missing then Im going to want to start to plot that.
