Old 12-03-2012, 02:19 AM   #3
Nimbus117
Nimbus117's Avatar
Originally Posted by nicecar View Post
remove 3 or 4 plastic anchors turn wheal to the left feel around as far as you can reach up near the frunk wall , that is where you will feel a metal braided cable with a loop pull firmly frunk will open. Trust me it is simple , my 11 year old and i did this the second night we owned the car. GOOD LUCK 02 S 107,238 miles
I wish you had sent your 11 year old over to me! I'm not sure if your liners the same as mine but it attaches to the front bumper so is pretty big, realistically you need to remove the wheel and the the liner on a 2003 - except I couldn't as the jack was in the front trunk.
In the end I discovered my charger was the problem, it is one of these smart ones that wont put out any power if it doesn't detects some voltage. I used a 12v battery connected to the tab in the fuse box and the door striker and then the trunk opened upon pressing the switch. A battery maintainer plugged into the cigarette lighter will not open the trunk if the negative lead is disconnected.
Hope this may be of help to others.
Nimbus117 is offline   Reply With Quote
