I would send it back anyway. You may get a new pump out of it. Then you will have a spare to use in 3 - 4 years when you replace the new one that you are going to put in now anyway. According to the recommendations of Flat 6, you should replace the water pump every 3 years, if I remember correctly.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
