Old 12-01-2012, 07:21 PM   #1
wawa
Better but still not running perfectly
Boxster 2000 S
Lately, the idle was bouncing a lot and shaking the car. When I was trying to drive a little hard, It feel like not much power and engine was often cuting power. When I depress the clutch, engine would die. Start again and was running ok, sometime à good cloud of smoke.
Now, last week I changed the MAF and clean the throttle body, but no change. Tonight I changed the AOS (not that easy) and now idle is really good, but I still have engine power cut out. Still no code. Next step in 2 days, I will change the spark plugs and the fuel filter.
Anything else worth to check while I'll be under the car?
Tanks
Chris
wawa is offline   Reply With Quote
