Old 12-06-2005, 01:35 PM   #5
bmussatti
Guest
Posts: n/a
Originally Posted by RandallNeighbour
I replaced the fuel sending unit and calibrated the unit. Didn't fix the fuel indicator.
What else could be causing it?
Randall, you say that it was calibrated. Are you sure it was calibrated correctly? I remember reading somewhere that the calibration process is fairly complex (drain tank, add a pre-set amount, calibrate...).
I can't find the article/posting. If I find it, I'll resend it to your attention.
