The reason it leaks going uphill is that maybe the oil is pooling in the triagulated alloy plate under the engine.
If you remove the plate, you should be able to locate the source of the leak.... possibly from the AOS, spark plug tubes or cambox seal.
2001 MV Agusta F4.
