Problem solved and who would have guessed what the solution was...
I moved two years ago and tried an independent shop closer to where I live now. Apparently, the local shop disconnected the rear level sensor and re-installed it so the sensor lever was 180 degrees off from its car level position. In essence, they put it in backwards so the car always thought it was in a nose down position. This tilted the low beams up to their highest angle.
I found this out this morning when I took the car back to the old shop and they put it up on the lift. After re-positioning the sensor lever, the litronics are working properly once again. Needless to say, I won't be using the local guys again.
