Old 12-05-2005, 07:06 AM   #2
bigislandboxster
Good call Randall.....I recently took a look on my '98 to see if I had the upgraded cables, and I did ......I would also make sure you have the 3/4" sticking out on the end as well( per ToolPants), even tho these cables are reinforced, they can also wear over time from use....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
