Old 11-27-2012, 10:59 AM   #2
Kenny Boxster
Moderator
Check to see how worn the tire in question is, and if any of the nylon thread is showing. That will give you a bad noise and shaking. Run your finger and see if you can feel the wear bar in between the rubber. That would probably be the easiest to check out.
