Well, upon further review, problem almost solved.
I have factory Litronics so they are self-leveling as JD pointed out. After I plugged in the passenger side cable, the leveling feature started working once again. With my Durametric, I am able to tilt the lights in all three positions - high, middle, or low.
I assume the default position, that is when the car is stationary on level ground in the garage, is the middle one. My car's default position tilts the lights to high. The front and rear sensor assemblies seem OK, meaning no obvious damage or breakage.
Am I correct that the default position is middle? If so, is this a problem that I need to take to the dealer to have the self leveling function re-programmed? If there is a way to reprogram it using the Durametric, I haven't figured out how to do that.
