Old 11-23-2012, 09:07 AM   #11
particlewave
Thanks for the compliments
Here's a rundown;
LEDs-
23 micro surface mount for the climate control unit
10 micro surface mount for all rocker switches(2 each)
5 small standard for the head light switch
2 large for the power outlet and "ashtray"(1 each)-these also require a resistor to drop the voltage from 12v to 3v.
The climate control and switch LEDs are pretty darn small, so a steady hand is a must. Check the orientation of the LEDs first and use a black sharpie to put a dot on the negative terminal of each(on the board). This will make things go faster
I think that I spent about 2 hours on the CC unit, which was the most work of course.
All in all, I'd say that I spent 4-5 hours on the whole project, though its hard to say for sure since it was spread out over several days.
The instrument cluster LEDs all came from porscheleds.com and took only a few minutes to swap out as the are just plug-and-play.
1-10, 10 being the most difficult, I'd rate the whole project a 5, but that is dependent upon the skill level of the individual.
