Old 11-22-2012, 05:45 AM   #34
Gorthaur
2000 Boxster S
i disconnect the battery almost every time i work on the car. never had issues.
if disconnecting the airbag (i.e. steering wheel, door panels, seats), wait at least 15 minutes between battery disconnect, to airbag disconnect.
the reason for that is, the airbag system includes capacitors that keep the system alive, even if the battery is damaged (like in an accident for example).
just make sure when you disconnect the battery, that the ignition is off. in fact, better if you keep the key in your pocket this time
in some cases, when the battery was disconnected for a long time, the RPM in idle are not stable at firs star up.
you need to drive the car for a wail, so the ECU and the MAF sensor can synchronize.
Thanks Heiko. Good point.
Thanks Meir. The question is: my car features the optional alam. Will keeping the key in my pocket and disconnecting the battery activate the alarm?
Gorthaur is offline   Reply With Quote
