Old 11-20-2012, 08:26 AM   #2
Homeboy981
Homeboy981
Homeboy981's Avatar
Hi @bebeto986,
Subs are a tough nut to crack! I have found with my 'small' 6.5" units in the doors that it is transferring a lot of rattles. I HATE rattles! Don't know how well our cars will hold up under BIG THUMPING! You might need to make your own enclosure. I have been looking at underneath and behind seats at an angle. Didn't like the passenger footwell sub ideas since they reduce passenger legroom, which is already at a premium.
Have an idea for using a couple 10" woofs using fiberglass custom made enclosure. But the power issue stopped me. As one person said, just get a Cat Back Exhaust and you will turn down the stereo to hear the REAL SYMPHONY!
Thought about putting in the trunk or frunk but they are sealed and you would have to "port" but then you are adding more road noise.
Also, you may be adding too much load to alternator. May cause you to have to upgrade IF you run an amp that is that much power.
Dunno, but let me know what you do. Let me hear the RFs thump from Houston!
