Old 12-02-2005, 06:30 AM   #1
GTrace
Arrow Speedline Wheels 3pc 18" new
:dance: The wheels are new, tires have never been mounted
18x8
offset 44 mm
Front spacing 74 mm
Backspacing 152 mm
mounting pad height to middle of spoke 37 mm
18x9
offset 44 mm
Front spacing 83 mm
Backspacing 170 mm
mounting pad height to middle of spoke 45 mm
Brand new set of Speedline 3pc "Aliseo" wheels. 18x8 front and 18x9 rear. $2000 for a set of 4. Email GTrace@msn.com or (478)929-9454. The Speedline wheels are being sold for a low price, because they are not 18x10. If an 18x10 inner rim half was available by Speedline, the set of 4 would cost $6000. If you must have an 18x10 rear, you can have two rim halves custom made from other wheel companies for $300 to $375 each. Another similar 3pc Speedline wheel is the Techart Daytona 18" wheels which ranges from $5500 and up. Most likely this is one of the last set of brand new original Speedline "Aliseo" wheels remaining worldwide.
GTrace is offline   Reply With Quote
