Old 11-18-2012, 05:12 AM   #2
Spinnaker
Spinnaker's Avatar
Fuel pump or the fuel pump relay would be my first guess.
Listen at the gas filler with the cap off while someone turns on the ignition. Do not start the car. You should hear a whirring sound coming from the gas tank when the key is turned to ignition on.
Running the gas tank down to empty can cause the fuel pump to overheat. The gasoline surrounding the pump helps keep it cool.
