The reason the converters are positioned as close as possible to the exhaust ports is to minimize the time it takes them to heat up to operating temp. Extending warm up time for converters will lite the CEL. To give you an idea how critical this is, Mercedes doesn't use 4-valve per cylinder heads on most of their engines because using only 1 exhaust valve per cylinder allows more heat retention for quicker warmup.
