Old 11-15-2012, 11:58 AM   #2
trimer
jakesbox
trimer's Avatar
Originally Posted by Heiko View Post
Do you have to drive it or does it do it when it sits and you hit the throttle too... could be a loose plug (yes they make that kind of noise) or you have a pulley/bearing that's chirps.
Checking the plugs is a bit of a pain because you have to pull the coils out, but I'd check that... if they're all tight, take the belt off and see if its gone... careful though dont run it too long the water pump is on the belt...
It only seems to happen under load. When sitting idle and revving, no noise...
