					Originally Posted by Heiko  Excellent - thank you kindly for that info.  I like the idea of re-using the connectors and the old speaker mounts.  When i took the Bose box appart behind the seats I noticed the old foam surrounds are starting to get a bit tacky so the foam is pretty much toast.  I'm not sure why they wouldnt use poly cones with rubber surrounds as they've been around way before 2000.  I guess it would cut into their profit margins     Ok i'm going to see if i can source some of these Kennwoods here and try the same.
Thanks again,
Heiko
Quick update.... 69 bux shipped to my door from Crutchfield.ca (and thats in CDN dollars) |
Here's a YouTube video of cutting the factory speaker and putting an aftermarket speaker in its place.
Porsche Boxster Speaker Replacement - YouTube
				__________________2001 Boxster - Arctic Silver Metallic
 RMS, IMS, 87.5K
