					Originally Posted by  Heiko
				I've been thinking about upgrading the speakers as well as i got way too much base coming from my speakers and even when i drop the base to -5 I still got way too much... its almost like the mid-tone is completely missing (maybe my hearing is going - so the wife tells me)
I'd prefer to keep it all stock without cutting or modifying but at the same time I'd hate to buy new crappy factory speakers.  I like Tony's approach in just replacing the dash ones... Tony do you have a Kennwood model # of the speakers you used available?  (sorry cant make it out on the little pics),  did you have to trim off the tabs on the new metal speaker case to get them to fit?
H
Heiko:
I purchased Kenwood KFC-1064S Flush mount 3 way speakers.
4Ω 120W peak power.
Kenwood - KFC-1064S
The 4" is a little smaller than the base of the old speaker, but they have bendable/break-off tabs that help with the fitment.
You will be surprise to see the stock paper cone speakers. Mine had some foam deteriorating.
You need an angled socket for the Torx screws for against the windshield.
I left the crossover tweeter in the speaker grille but left the wires disconnected.
I used a dremel to cut the old speaker out to reuse the base.
Epoxy the new speaker to the base of the old speaker..
I also used the old connector and soldered it onto the new speaker.
That way I could just simply plug them in to the factory connector.
hope that helps.
T
