Old 11-13-2012, 06:26 AM   #10
Gorthaur
2000 Boxster S
Originally Posted by Ghostrider 310 View Post
Get it up on stands with the rear wheels off. Check for "openings, like a little door" in the inner fender well that facilitate access to the coils and plugs, if they aren't there simply go in from underneath. Each set of three plugs on each bank has it's own discreet coil. What Heiko is saying is to locate the connector on each coil and one by one disconnect them. You are looking for the disconnection that makes no difference at all as each other time you disconnect a working coil you are creating a miss which should make the engine stumble more. Hope that helps.
Thanks again. Unfortunately I have no stands and there's not enough room to remove the wheels either. She sits in a small box inside an underground garage which is 70 cm wider then the car itself... I'm going tu bury her down there... Really pissed off!
Gorthaur is offline   Reply With Quote
