Old 11-12-2012, 10:59 PM   #225
BruceH
BruceH's Avatar
Originally Posted by trimer View Post
Can you please share your method? Did you just take time and wipe everything down going through towel after towel or did you spray it with clearner and then with water??? Looks great!
Thanks! I did a little bit of both. I sprayed on an orange cleaner from HD and let it sit for a few minutes, rinse and repeat a few more times. I used rags to work on the stubborn areas and sprayed and rinsed some more. I used very gentle water to rinse, staying away from electical connections as much as I could. I thoroughly dried as much as I could as well. I was quite pleased at how well the orange cleaner worked and I am very happy with the results! I don't think that it was ever cleaned since the day it left the factory judging from what I saw.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
