			there should be 2 thinwall PVC tubes that fit in the  rear drain holes.  These tubes keep the water from seeping between the foam.   I made sure that they were at the proper height  (flush) for complete drainage and then sealed around the edge with "Elmers " old fashion glue to seal the tube to the foam.  With " Elmers" there is no chemical reaction or distruction to the foam.  The tubes are about...1/2 '' ib X 4''
