+1 JFP in PA
1st and 2nd gear on the lower shaft are part of the drive shaft in the gear box and the
others float. If you leaked enough fluid to run these dry they will likely whine as any friction will transfer through the shaft. (The floating gears usually dont transfer noise as much)
I would check my tranny fluid before driving it any further, if you top it up and the noise is gone you might have caught it in time.
H
Previously owned:
