Old 11-07-2012, 02:59 PM   #5
oc-boxster
oc-boxster's Avatar
took the car to pep boys to get codes pulled, only 1 code came up p0430. cat converter conversion too low cylinders 4-6, did a search and it gave some ideas about cleaning the maf sensor running some techron additive to the gas then driving it pretty hard and to check the 02 sensors and harneses, ill try these things along with disconnecting the battery and starting over..just seems odd i never had a cel light until the same day i get a new battery..one good thing the search said is that it is very rarely the expensive cat converters that go bad.
oc-boxster is offline   Reply With Quote
