			@ thstone
 There is no existing crack in the liner as I covered every suspected crack with a dynamat type of material. I even tested it if everything goes down the drainhole of the foam liner and it seems all was well. I just cant tell if the leak is between the foam liner drainhole and the drain hose mouth since I cant see underneath but there is a space in between them.
 @ Meir
 Yes I also unclogged it was well. Pumped it with airpressure and it seems all water went inside the hole when tested.
 Any other input guys?
