Thread: drain holes
Old 11-07-2012, 04:10 AM   #6
jcb986
jcb986's Avatar
I pour a little water in the holes first, then I use my air compressor to blow the remainder out. You do not want to damage them, then you will have a bigger problem. The ones inside your top area can cause water to enter the cabin, be very careful with those. Once cleaned, I simulate a nasty down pour. I pour a bout quart of water through each, if flows nicely, the drains are open, if not, then clean them again.:dance:
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
