Old 11-04-2012, 05:37 PM   #2
sb01box
you did not specify model year but if it's 986 series, can you lock the car?
most likely the micro switch in the door mechanism is faulty and is telling the system that the door is open. it's the same switch that keeps the window 1/4 inch down when the door is open and once the door is closed (and the micro switch is in the opposite position) the window control processor raises the window the last 1/4 of an inch.
sb01box is offline   Reply With Quote
