Old 11-04-2012, 11:54 AM   #1
gowestwarho
gowestwardho
'01 S Soft Top stopped working. Any stepxstep instructions for diagnosis?
My soft top has suddenly stopped working. The dash light remains ON all the time. I can hear a motor running under the top and it sounds like it is cycling through its forward-and-back routine (I am led to believe it is a continuous loop or rather a single cable with reversing indicators on each end or something).
I have checked the usual - emergency brake completely set. Fuses OK, etc.
So what do I do next? How do I open the top when it doesn't cycle even halfway at all (i.e., I know how to open the engine compartment, et al, when the top is opened halfway. But in this case the metal body cover between the top itself and the trunk is in the locked and closed position).
What are the usual suspects to check for? BTW, I have 65,000 miles on it) Thank you
gowestwarho is offline   Reply With Quote
