Old 11-02-2012, 09:44 PM   #5
trygve
This kind of noise is hard to diagnose. The anti-sway bar will have a little bit of side-to-side play because it is meant to rotate in those bushings (just left of where you are pointing), and because the drop links don't prevent side-to-side movement (*). Make sure that if you wiggle the bar that it has no radial play in the bushing. Rotate, yes. (You'd have to disconnect the drop links to rotate it by hand.) Slide horizontally a little bit, ok. Move in the direction of the car (front-back), no.
(*) I am not sure about the stock bar, but on my Tarrett bar there are little circular clamps that go around the bar just outside of each bushing, to limit the horizontal movement.
trygve is offline   Reply With Quote
