hj hoser
the mass air flow regulator can be a problem. check rear plastic window specially if it was lowered under 17 degrees, it can go white or crack on the edges at the folding level, i also had to change water pump and main belt due to one breaking the other(i don't know which one broke first) all this happen on my previous 97 tip boxster
