You said you wanted opinions.... I don't think the jack stands are that big a deal if you are very careful as you raise the car higher than normal. If you don't have a spot where it can sit on said stands all winter that's a whole different issue. If you take your time and have the good sense to stop when things are not going according to plan, you should be fine. You always have here to get info and even if things do go askew determination will win the day once you decide you will not give up until the task is complete. If the garage isn't heated get a propane bullet, I had one blowing on me all winter when I took apart my 986.
