The other thing you can do is pop the tray out of the center console (2 torx screws) and look inside there. You will be able to get at the switch and jiggle it to see if the brake light will come on. Failing that you can pull out the connector and short it as a way to get the top working until you have time to replace the switch.
Oo look... post # 986!
'99 black 986
