Old 10-29-2012, 07:35 AM   #2
b55er
b55er's Avatar
Stephe57,
What you said and what the dealer said kinda makes sense.
They were telling me that the Alarm module passcode obtained by PCNA was not correct.
Now.. Either the database is incorrect.. or the module is bad in some way. As I said earlier, the car runs and drives fine with it's one key. As far as I know, the module has never been replaced.
I wanted to check with the forum in case the dealer was BSing me and wanted to turn two keys from a $300 experience into a $700 one.
Obtaining two extra keys has turned into an expensive ordeal. Does the dealer update the PCNA database if a new module is added? After this lesson learned, I understand that I will ask the dealer to provide me with all the coding information for the car.
Any other options to add keys to the car? If I swap the Alarm module out, I assume it has practically no value on the used market due to the unknown password issue. Can it be reprogrammed/flashed?
Thanks again,
B55er..
b55er is offline   Reply With Quote
