There are four bolts that keep the seat rails firmly attached to the bottom of the car. Check to see if all four bolts are tight.
If they are, then you should probably pull the seat to inspect it from the underside and see what's loose. You might find some bolts and nuts under the seat when you remove it.
Word of advice: Disconnect your battery for a half hour BEFORE you remove the seat and unplug anything. This will keep your airbag light from coming back on when you're done.
