Hey Tony,
Good work BTW. I understand about half of it...kidding. You ARE way over my head on the circuit thing. Don't know if this will help you solve it but the LED Mfr. say to use some load resistors in the circuit if it does not function with a flasher thingy. I have several of these load resistors - they are surprisingly large and must be, I guess, to turn electrical energy in to heat(?)
The load resistors I have but am unsure if it will even work if I use them are: 25watt and 6 ohm & 50watt and 6 ohm. Don't know if that helps. The electronic flasher was picked up at NAPA. It says for use with LEDs, WTH? Could it be another flasher or circuit that is hijacking all our good work?
I looked all over for answers but have yet to see any way to solve this LED debacle. I bought all these parts and hate to not use them. Especially since they would make our cars looks SO GOOD.
Don't worry Fury, they will NOT LOOK as good as yours! Your car is unique, for now. I may just dump the single bulb junk and get ones like yours…unless you can figure it out though! he-he (NOTE: that was an attempt at motivation)
Thanks for the deep research either way - I was lucky to get someone to respond much less do clinical trials!
"It takes a smart person to make our cars shine, even if it is not the owner!"
Thanks Again!
