Old 10-26-2012, 10:25 AM   #5
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
Originally Posted by tt2008 View Post
The door lock is not just covered, I Think is has ben broken or something, there are just a hole, and can't get the key in....
The key batteri is almost new and the red led in the key is lighting, I'm almost sure that the problem is the car batteri.....
Jumper cable connection on the fuse box is not going to help you if the door is inaccessible...
Dilemma..
Bad options...
Break a window, report it to your insurance as vandalism...
The question is, cut the plastic window and crawl through, or break a glass window..?
I would think it would be cheaper to replace a window than a top..
Although none the above options are cheap..
RMS, IMS, 87.5K
