Old 10-26-2012, 06:23 AM   #35
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
thanks tony, ill give it a try.
where did you get the bulbs for the DEPO, and are you using the same bulbs for the front turn signal (the ones in the head light)?
Meir:
The model DEPO rear lights were designed with light bulbs for turn signals and reverse lights, the front headlights have LED's built in. White LED's that flash amber when engaged. I'm not certain if the LED circuitry has built in load resistors. But the combination of the front and rears do not cause the hyper flash. I also change the 3rd brake light with a LED model and it didn't need load resistors. Had no ill effects that some members encountered with the cruise control not engaging that I read.
T
Size:  87.8 KBName:  IMG_0371.jpg
RMS, IMS, 87.5K
