It's pretty easy to mount it above and slightly to the right of the mirror. You can run the cable in the area above the mirror and down the right side. There are instructions somewhere on the rennlist site. Power is available via an RJ11 cable behind the climate control unit. Just tap into the green/black wire, attach the ground wire, and you'll be set. I did mine over the weekend.
2002 Triple-Black Boxster S
