Old 10-24-2012, 08:57 PM   #16
tony_fury
2001 Arctic Silver 2.7
tony_fury's Avatar
Originally Posted by crogers106 View Post
I purchased the Depo tail light's and followed the instructions in the link below and now have LED turn signals and tail lights. Had to install resistors and instruction step #5 is incorrect. I had to install one resistor wire to the black wire and the other to the red to prevent hyper blink.
Not sure it was worth the trouble but I like it.
Anti-Bling Porsche Boxster DIY's
Crogers106:
You can install a LED Flasher relay instead of the load resistors.
3 PIN ELECTRONIC LED FLASHER BLINKER FIX 1157 3157 7443
This will stop the hyper blink without putting load resistors across the power leads.
The relay designed to handle the lower current draw.. Load resistors can heat up, hence the heat sink they put the resistor around..
T
RMS, IMS, 87.5K
