Old 10-24-2012, 05:02 PM   #1
BYprodriver
BYprodriver's Avatar
Sorry but cannot find which sealant is the recommended for the oil pan cover.
I will be changing the oil and wanted to check the inside of the oil pan (4 curiosity and to check for debris), my engine has 60k
I remember reading that you can use a motorcycle engine case sealer, called Yamabond.. (?) or something like that..
What do you recommend?
Thank you in advance.
Gilles, the best is 3 Bond 1209 or Drei Bond by Porsche. Circle Porsche in Long Beach stocks this. $18. I believe YamaBond is simular or identical.
Loctite 5900 is good, but hard to remove the part later & clean off.
Permatex Ultra Grey is good & available at most auto parts stores $7.00, since the oil sump plate is easy to seal I recommend this.
