Old 10-23-2012, 03:51 PM   #159
tuanle16
[QUOTE=PCC010;304189]The fitment is perfect; its the seal on the passenger side which sits slightly higher than the car body. Approx 4 inches at the top.
I understand what you mean with the click - after pulling and installing the lights you get used to the click!
Daytime running you get plenty of admirers - it really has moved the age of the car forward.
Set the lights up (pain in the but pull out / install each time you make an adjustment, but I suppose once you've done it, its done.
As the lights are a projector reflector cut off is pronounced - used to it as the Evo has projector lights fitted.
The original Porsche lights were good - are these better - difficult to say, just take some getting used to. I'm running Philips H1 Visionstreams for the drive / main beam and H7 Extreme Power for the fogs.
are you saying that you don't get a click now?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
