Old 10-23-2012, 04:36 PM   #2
Jittsl
SPB racer
I don't know it as a certainty that it won't work but I would be very concerned about subtle differences that make them incompatible and requiring modification. There were many changes in the transistion from 99-2000. I would be stunned if they were simply plug and play.
I find it hard to believe that you cant find a pod from a 97-99 or even an early 996 (which would add the volt and oil pressure gauges and I think is documented as a modification on the Pelican site). I'm pretty certain if you called around the usual suspects or waited on eBay you would find what you need.
Not much help but all I got.
Jittsl is offline   Reply With Quote
