Old 11-28-2005, 06:17 AM   #5
mjw930
Originally Posted by JebLacey
So I cleaned my battery posts/connectors, cleaned the ground, and the connector for the Pos. into the firewall. I checked the connectors on the DME and the Tip. controller, but dont know which is which (checked both, both secure and appear in good order). Went to start it... no CEL test light. Tryed to start anyway, and of course, no luck. Starter just spun.
How do I disconnect the DME and Tip Cont. Want to check the connections themselves... Do i have to un-mount them from the wall?
At this point I think the dealer or a good independant shop who knows the Boxster / 996 electronics is your best solution. If could be something as simple as a failed relay.
mjw930 is offline   Reply With Quote
