BTW, I highly recommend you use Meguires plasiX to remove scratches on the plastic lenses. It's what Meguires puts in their headlight restoration kit to use after you've sanded off all the oxidized plastic from the face of a headlamp assembly. Works amazingly well to remove scratches on most any plastic surface and makes it crystal clear.
Just remember to use a dab on a new microfiber cloth and don't rub too hard and do one and then clean it off and have a look before you do the other two.
Hope this helps!
