Originally Posted by Brockmeister
I have the same problem. However, I bypassed the clutch switch, Still no go. I guess I'll try a new ignition switch. I'm at a loss. Car will run if jumped from another car.
I spoke with one of the dealers and they said the cable from the starter to the terminal block goes bad sometimes...more common in 911's but they've seen it boxsters
Then clearly it's spark power loss. Pull the battery connectors and clean them. Double the cable with a jumper cable from starter to terminal block to check line. Could be the switch too as you already surmised.
