Pull the bearing... if there is no large piece of metal that actually made it into the engine and the bearing was just starting to decompose then you probably got away lucky.... I would pull the sump plate though and make sure you clean everything well... a flush of the engine after you're done the work probably wouldnt hurt....
Anyhow thats just my opinion...
Previously owned:
