Thread: gear ratios
Old 10-16-2012, 10:46 PM   #10
The Radium King
The Radium King's Avatar
street/track use. 3rd gear gets very vague when things heat up at the track; hoping a trans cooler would fix it. that's why i don't want to get too fancy with a temp sensor triggering the pump or anything; just turn it on at the track and off on the street. also don't want to be drilling the case; if i can fix the issue just by repurposing the drain and fill openings then i am happy. given my intended use a check valve seems a good idea; thanks.
