Originally Posted by Mrmaddbrad
Check tire pressures, and get it aligned.
However, they will never feel the same. The steering feel on 987's are not nearly as responsive as the 986. That is not going to change. If you feel like it seems wrong, it probably is. As previously stated by Topless, my car also feels completely solid at well over 100, but even at moderate highway speeds you can "feel" the road through the steering wheel. I think that makes it feel more like a sports car and actually enjoy it, but that's just me.
I think this is probably it. It is more road feel that I'm probably feeling. Tire pressure is 30/34, I check it all the time and have even messed around with different pressures. Rims aren't bent since I had them checked when I got my tires put on recently. Current alignment is the following (all in degrees). I double checked it with my home alignment system also to make sure (I can check camber and toe with my setup):
Front:
Camber -0.5/-0.5
Caster 7.7/7.6
Toe 0.03/0.06
Steer ahead -0.01
Rear:
Camber -1.6/-1.6
Toe 0.11/0.12
Thrust 0.00
