Old 10-15-2012, 08:03 AM   #13
shadrach74
Is it common to have all 4 wheels wear at the same rate? Mid engined or not, this sounds fishy as does the rest of this dealer's story... Every other car I've owned has typically gone through 2 sets of pads up front for every set of rears. Unless your beating the hell out of it or tracking it regularly, rear pads should last way more than 25K. Even fronts ought to do better than that on a car that is used reasonably with the occasional spirited run down a back road...
shadrach74 is offline   Reply With Quote
